F
Frank1313
Aku WRITE A PROGRAM UNTUK DO A Comunication, I2C BUS MENGGUNAKAN DAN 2 PIC16F876 ..
THE SLAVE Assembler PENGGUNAAN, DAN KURASA IS OK
THE MASTER PICBASICPRO PENGGUNAAN, DAN TIDAK BISA MENERIMA DATA.
INI MENGGUNAKAN CONFIGURATION:
MENDEFINISIKAN HSER_BAUD 19.200
MENDEFINISIKAN I2C_SLOW 1
MENDEFINISIKAN ONINT_USED 1 'Bootloader
SCL VAR PORTC.3 'Jam pin
SDA VAR PORTC.4 'Data pin
VAR FromSlave BYTE 'dati arrivati dallo slave
Letture VAR BYTE 'Dati letti da ADC (funzione non implementata)
Test VAR PORTA.0
SSPCON =% 00101000 'Setta il dispositivo di Master Mode
SSPADD =% 00001001 '100KHz con Fosc 4MHz
PORTA = 0
TRISA =% 11111110
PORTB = 0
TRISB = 0
PORTC = 0
TRISC =% 10111111
FromSlave = 0
Ciclo:
I2CRead SDA, SCL, 2, [FromSlave], errore
GoTo Ciclo
Test VAR PORTA.0
PORTA = 0
TRISA =% 11111110
PORTB = 0
TRISB = 0
PORTC = 0
TRISC =% 10111111
FromSlave = 0
Ciclo:
GoTo Ciclo
