ane ada tugas kuliah tentang "booth multiplier" menggunakan VHDL. Software yang ane gunain ISE 10.1 dan modelsim III 6.3. Berikut listing program yang ane coba jalankan:
-- Booth Multiplier
-- This file contains all the entity-architectures for a complete
-- k-bit x k-bit Booth multiplier.
-- the design makes use of the new shift operators available in the VHDL-93 std
-- this design passes the Synplify synthesis check
-- download from: www.fpga.com.cn & www.pld.com.cn
--top level design unit
library IEEE;
use IEEE.Std_logic_1164.all;
ENTITY booth_multiplier IS
GENERIC(k : POSITIVE := 7); --input number word length less one
PORT(multiplicand, multiplier : IN BIT_VECTOR(k DOWNTO 0);
clock : IN BIT; product : INOUT BIT_VECTOR((2*k + 1) DOWNTO 0));
END booth_multiplier;
ARCHITECTURE structural OF booth_multiplier IS
SIGNAL mdreg, adderout, carries, augend, tcbuffout : BIT_VECTOR(k DOWNTO 0);
SIGNAL mrreg : BIT_VECTOR((k + 1) DOWNTO 0);
SIGNAL adder_ovfl : BIT;
SIGNAL comp ,clr_mr ,load_mr ,shift_mr ,clr_md ,load_md ,clr_pp ,load_pp ,shift_pp : BIT;
SIGNAL boostate : NATURAL RANGE 0 TO 2*(k + 1);
BEGIN
PROCESS --main clocked process containing all sequential elements
BEGIN
WAIT UNTIL (clock'EVENT AND clock = '1');
--register to hold multiplicand during multiplication
IF clr_md = '1' THEN
mdreg <= (OTHERS => '0');
ELSIF load_md = '1' THEN
mdreg <= multiplicand;
ELSE
mdreg <= mdreg;
END IF;
--register/shifter to product pair of bits used to control adder
IF clr_mr = '1' THEN
mrreg <= (OTHERS => '0');
ELSIF load_mr = '1' THEN
mrreg((k + 1) DOWNTO 1) <= multiplier;
mrreg(0) <= '0';
ELSIF shift_mr = '1' THEN
mrreg <= mrreg SRL 1;
ELSE
mrreg <= mrreg;
END IF;
--register/shifter accumulates partial product values
IF clr_pp = '1' THEN
product <= (OTHERS => '0');
ELSIF load_pp = '1' THEN
product((2*k + 1) DOWNTO (k + 1)) <= adderout; --add to top half
product(k DOWNTO 0) <= product(k DOWNTO 0); --refresh bootm half
ELSIF shift_pp = '1' THEN
product <= product SRA 1; --shift right with sign extend
ELSE
product <= product;
END IF;
END PROCESS;
--adder adds/subtracts partial product to multiplicand
augend <= product((2*k+1) DOWNTO (k+1));
addgen : FOR i IN adderout'RANGE
GENERATE
lsadder : IF i = 0 GENERATE
adderout(i) <= tcbuffout(i) XOR augend(i) XOR comp;
carries(i) <= (tcbuffout(i) AND augend(i)) OR
(tcbuffout(i) AND comp) OR
(comp AND augend(i));
END GENERATE;
otheradder : IF i /= 0 GENERATE
adderout(i) <= tcbuffout(i) XOR augend(i) XOR carries(i-1);
(tcbuffout(i) AND carries(i-1)) OR
(carries(i-1) AND augend(i));
END GENERATE;
END GENERATE;
--twos comp overflow bit
adder_ovfl <= carries(k-1) XOR carries(k);
--true/complement buffer to generate two's comp of mdreg
tcbuffout <= NOT mdreg WHEN (comp = '1') ELSE mdreg;
--booth multiplier state counter
PROCESS BEGIN
IF boostate < 2*(k + 1) THEN boostate <= boostate + 1;
ELSE boostate <= 0;
END IF;
END PROCESS;
--assign control signal values based on state
PROCESS(boostate)
BEGIN
--assign defaults, all registers refresh
comp <= '0';
clr_mr <= '0';
load_mr <= '0';
shift_mr <= '0';
clr_md <= '0';
load_md <= '0';
clr_pp <= '0';
load_pp <= '0';
shift_pp <= '0';
IF boostate = 0 THEN
load_mr <= '1';
load_md <= '1';
clr_pp <= '1';
ELSIF boostate MOD 2 = 0 THEN --boostate = 2,4,6,8 ....
shift_mr <= '1';
shift_pp <= '1';
ELSE --boostate = 1,3,5,7......
IF mrreg(0) = mrreg(1) THEN
NULL; --refresh pp
ELSE
load_pp <= '1'; --update product
END IF;
comp <= mrreg(1); --subract if mrreg(1 DOWNTO 0) ="10"
END IF;
END PROCESS;
END structural;
Pada saat ane tes sintesis di "MODUL VHDL" terdapat warning tapi sukses sintaxnya:
WARNING:Xst:819 - "D:/KULIAH/DATA_FPGA/10_des_2011/booth/booth.vhd" line 105: One or more signals are missing in the process sensitivity list. To enable synthesis of FPGA/CPLD hardware, XST will assume that all necessary signals are present in the sensitivity list. Please note that the result of the synthesis may differ from the initial design specification. The missing signals are:
WARNING:Xst:646 - Signal <adder_ovfl> is assigned but never used. This unconnected signal will be trimmed during the optimization process.
Pada saat disimulasikan dimodel sim :
# ** Error: boothwav.vhw(43): String literal has a character 'Z' not in the enumeration type std.standard.bit.
# ** Error: boothwav.vhw(95): VHDL Compiler exiting
# ** Error: C:/Modeltech_xe_starter/win32xoem/vcom failed.
Mohon bantuannya...
Klo repost maaf ya gan... ;D
-- Booth Multiplier
library IEEE;
BEGIN
BEGIN
ELSE
mdreg <= mdreg;
END IF;
mrreg(0) <= '0';
ELSE
mrreg <= mrreg;
END IF;
ELSE
product <= product;
END IF;
END PROCESS;
GENERATE
END GENERATE;
END GENERATE;
END GENERATE;
PROCESS BEGIN
ELSE boostate <= 0;
END IF;
END PROCESS;
PROCESS(boostate)
BEGIN
comp <= '0';
clr_mr <= '0';
load_mr <= '0';
shift_mr <= '0';
clr_md <= '0';
load_md <= '0';
clr_pp <= '0';
load_pp <= '0';
shift_pp <= '0';
load_mr <= '1';
load_md <= '1';
clr_pp <= '1';
shift_mr <= '1';
shift_pp <= '1';
NULL; --refresh pp
ELSE
END IF;
END IF;
END PROCESS;
END structural;
Mohon bantuannya...
