S
Sheeraz Khan
Can anybody menggambar skema kode terdaftar?
; Pulse_60.asm
; 22 Oktober 2004
; Keluaran 1 pulsa / menit dari 50Hz utama atau jam 0.5Hz sirkuitdaftar P = 3D 12F675
termasuk "P12F675.inc"
errorlevel -305, -302, -306; MPLAB kesalahan penekanan
__CONFIG _CP_OFF & _INTRC_OSC_NOCLKOUT & _WDT_OFF & _BODEN_OFF & _PWRTE_ON & _BODEN_OFF & _MCLRE_ON
bank0 makro
bcf Status, Rp0
bcf status, Rp1
bcf status, irp
endm
bank1 makro
bsf Status, Rp0
bcf status, Rp1
bcf status, irp
endm
mov makro litval, file
movlw litval
file movwf
endm
cblock 0x20
kutu
secs
temp1
temp2
t0_cnt
endc
# define dipimpin gpio, 0; 1 ppm LED
# define kekuasaan gpio, 1; induk di
# define mains50 gpio, 2; 50Hz di, INA
# define b0int gpio, 4; keluar untuk 452
# define jam gpio, 5; 0.5Hz dari modul jam
org 0x00
goto start
org 0x04
goto isr
org 0x05
mulai bank1
panggilan 0x3ff
movwf osccal
clrf Ansel; digital input
movlw b'00101110 '
, 1 0.5Hz di
; 0 output ke 452
; 1 / mclr
, 1 50Hz di
, 1 utama on / off
; 0 LED hijau, output
movwf trisio
movlw b'10000110 '
; 1 pullups off
; 110 / 128 TMR0 pre-scaler
movwf option_reg; = 3D ~ 32.768ms rollover 4MHz int RC = oscbank0
clrf gpio
movlw b'00000111 '; 0,1,2 sebagai digital GPIO
movwf cmcon
clrf tmr0
clrf intcon
bsf intcon, inte
clrf t1con
mov 0xff, tmr1l; beban TMR1 dengan -1
mov 0xff, tmr1h
mov ,100, kutu; 2 detik resolusi
mov ,30, secs; 1 menit
; = 3D = 3D = 3D = 3D = 3D = 3D = 3D = 3D = 3D = 3D = 3D = 3D = 3D = 3D = 3D = 3D = 3D = 3D = 3D = 3D = 3D = 3D = 3D = 3D = 3D = 3D = 3D = 3D = 3D = 3D = 3D = 3D = 3D = 3D = 3D = 3D = 3D = 3D = 3D = 3D = 3D = 3D = 3D = 3D = 3D = 3D = 3D = 3D
; Main loop, menunggu input
btfss utama kekuasaan
goto baterai
bcf intcon, intf
clrf tmr0
wt_lh btfsc mains50
goto chk_m1
wt_hl btfss mains50
goto chk_m2
bcf dipimpin
decfsz ticks
goto utama
mov ,100, kutu; reload ticks
bsf memimpin; 1/50th LED pada kedua
decfsz secs
goto utama
mov ,30, secs; reload secs
panggilan nadi
goto utama
btfss baterai jam
goto sec2; proses jika Mematikan daya
btfsc kekuasaan
goto utama; keluar jika kekuatan datang di
goto baterai
sec2 bsf dipimpin
panggilan ms5; LED selama 5ms
btfss jam; menunggu untuk kembali tinggi
goto -1 $
bcf dipimpin
decfsz secs
goto baterai
mov ,30, secs
panggilan nadi
goto baterai
nadi bsf b0int; 50us pulsa ke 452
mov ,252, temp1
incfsz temp1
goto -1 $
bcf b0int
kembali
kekuasaan chk_m1 btfss
goto baterai
goto wt_lh
kekuasaan chk_m2 btfss
goto baterai
goto wt_hl
ms5 mov ,249, temp1; 5ms penundaan
mov 0x84, temp2
inct1 incfsz temp2
goto -1 $
incfsz temp1
goto inct1
kembali
; Fault - TMR0 time-out
isr nop
t_loop bcf intcon, t0if; approx delay 500us
btfss intcon, t0if
goto -1 $
bcf intcon, t0if
kembali
akhir
; Pulse_60.asm
; 22 Oktober 2004
bank0 makro
bcf Status, Rp0
bcf status, Rp1
bcf status, irp
endm
bank1 makro
bsf Status, Rp0
bcf status, Rp1
bcf status, irp
endm
movlw litval
file movwf
endm
cblock 0x20
kutu
secs
temp1
temp2
t0_cnt
endc
org 0x00
goto start
org 0x04
goto isr
org 0x05
mulai bank1
panggilan 0x3ff
movwf osccal
movlw b'00101110 '
, 1 0.5Hz di
; 0 output ke 452
; 1 / mclr
, 1 50Hz di
, 1 utama on / off
movwf trisio
movlw b'10000110 '
; 1 pullups off
clrf gpio
movwf cmcon
clrf tmr0
clrf intcon
bsf intcon, inte
clrf t1con
mov 0xff, tmr1h
goto baterai
bcf intcon, intf
clrf tmr0
wt_lh btfsc mains50
goto chk_m1
wt_hl btfss mains50
goto chk_m2
bcf dipimpin
decfsz ticks
goto utama
decfsz secs
goto utama
panggilan nadi
goto utama
btfss baterai jam
btfsc kekuasaan
goto baterai
sec2 bsf dipimpin
goto -1 $
bcf dipimpin
decfsz secs
goto baterai
mov ,30, secs
panggilan nadi
goto baterai
mov ,252, temp1
incfsz temp1
goto -1 $
bcf b0int
kembali
goto baterai
goto wt_lh
goto baterai
goto wt_hl
mov 0x84, temp2
inct1 incfsz temp2
goto -1 $
incfsz temp1
goto inct1
kembali
isr nop
btfss intcon, t0if
goto -1 $
bcf intcon, t0if
kembali
akhir
